CCS/IWR1443BOOST: MmwDemo_transmitProcessedOutput Function
Part Number: IWR1443BOOST
Other Parts Discussed in Thread: IWR1443
Hi
I'm working with IWR1443Boost High-Accuracy software(1TX,1RX), and i have a question about IWR1443 MmwDemo_transmitProcessedOutput function in Main.c ..
How can i modify the code so the output message would be only the Detected Objects, without Header/Range Profil/Stats info?
Richard
  • Hi Richard
    You would simply remove the unwanted packets from your UART stream. It would then need to be decoded differently than is done in the standard High Accuracy Visualizer.
    It is not recommended to remove the header including magic word.
    AG
