Compiler/IWR6843ISK: readUartCallbackFcn(hDataSerialPort, 0); Invalid
Part Number: IWR6843ISK
Other Parts Discussed in Thread: IWR6843
I tried to run below this Matlab code which I got from the other forum, but why readUartCallbackFcn(hDataSerialPort, 0); function invalid, I just I to know can I use this code for IWR6843 ES 1.0?
%Read bytes
if BYTES_AVAILABLE_FLAG == 1
BYTES_AVAILABLE_FLAG = 0;
%fprintf('bytevec_cp_len, bytevecAccLen = %d %d \n',bytevec_cp_len, bytevecAccLen)
if (bytevec_cp_len + bytevecAccLen) < bytevec_cp_max_len
bytevec_cp(bytevec_cp_len+1:bytevec_cp_len + bytevecAccLen) = bytevecAcc(1:bytevecAccLen);
bytevec_cp_len = bytevec_cp_len + bytevecAccLen;
bytevecAccLen = 0;
else
fprintf('Error: Buffer overflow, bytevec_cp_len, bytevecAccLen = %d %d \n',bytevec_cp_len, bytevecAccLen)
end
end
bytevecStr = char(bytevec_cp);
magicOk = 0;
startIdx = strfind(bytevecStr', char([2 1 4 3 6 5 8 7]));
if ~isempty(startIdx)
if startIdx(1) > 1
bytevec_cp(1: bytevec_cp_len-(startIdx(1)-1)) = bytevec_cp(startIdx(1):bytevec_cp_len);
bytevec_cp_len = bytevec_cp_len - (startIdx(1)-1);
end
if bytevec_cp_len < 0
fprintf('Error: %d %d \n',bytevec_cp_len, bytevecAccLen)
bytevec_cp_len = 0;
end
totalPacketLen = sum(bytevec_cp(8+4+[1:4]) .* [1 256 65536 16777216]');
if bytevec_cp_len >= totalPacketLen
magicOk = 1;
else
magicOk = 0;
end
end
byteVecIdx = 0;
if(magicOk == 1)
%fprintf('OK, bytevec_cp_len = %d\n',bytevec_cp_len);
if debugFlag
fprintf('Frame Interval = %.3f sec, ', toc(tStart));
end
tStart = tic;
[Header, byteVecIdx] = getHeader(bytevec_cp, byteVecIdx);
detObj.numObj = 0;
for tlvIdx = 1:Header.numTLVs
[tlv, byteVecIdx] = getTlv(bytevec_cp, byteVecIdx);
switch tlv.type
case MMWDEMO_UART_MSG_DETECTED_POINTS
if tlv.length >= OBJ_STRUCT_SIZE_BYTES
[detObj, byteVecIdx] = getDetObj(bytevec_cp, ...
byteVecIdx, ...
tlv.length, ...
Params.dataPath.rangeIdxToMeters, ...
Params.dataPath.dopplerResolutionMps, ...
Params.dataPath.numDopplerBins);
end
case MMWDEMO_UART_MSG_RANGE_PROFILE
[rp, byteVecIdx] = getRangeProfile(bytevec_cp, ...
byteVecIdx, ...
tlv.length);
case MMWDEMO_UART_MSG_NOISE_PROFILE
[np, byteVecIdx] = getRangeProfile(bytevec_cp, ...
byteVecIdx, ...
tlv.length);
case MMWDEMO_UART_MSG_AZIMUT_STATIC_HEAT_MAP
[Q, byteVecIdx] = getAzimuthStaticHeatMap(bytevec_cp, ...
byteVecIdx, ...
Params.dataPath.numTxAzimAnt, ...
Params.dataPath.numRxAnt,...
Params.dataPath.numRangeBins,...
NUM_ANGLE_BINS);
case MMWDEMO_UART_MSG_RANGE_DOPPLER_HEAT_MAP
[rangeDoppler, byteVecIdx] = getRangeDopplerHeatMap(bytevec_cp, ...
byteVecIdx, ...
Params.dataPath.numDopplerBins, ...
Params.dataPath.numRangeBins);
case MMWDEMO_UART_MSG_STATS
[StatsInfo, byteVecIdx] = getStatsInfo(bytevec_cp, ...
byteVecIdx);
%fprintf('StatsInfo: %d, %d, %d %d \n', StatsInfo.interFrameProcessingTime, StatsInfo.transmitOutputTime, StatsInfo.interFrameProcessingMargin, StatsInfo.interChirpProcessingMargin);
displayUpdateCntr = displayUpdateCntr + 1;
interFrameCPULoad = [interFrameCPULoad(2:end); StatsInfo.interFrameCPULoad];
activeFrameCPULoad = [activeFrameCPULoad(2:end); StatsInfo.activeFrameCPULoad];
guiCPULoad = [guiCPULoad(2:end); 100*guiProcTime/Params.frameCfg.framePeriodicity];
if displayUpdateCntr == 40
UpdateDisplayTable(Params);
displayUpdateCntr = 0;
end
otherwise
end
end
byteVecIdx = Header.totalPacketLen;
if ((Header.frameNumber - packetNumberPrev) ~= 1) && (packetNumberPrev ~= 0)
fprintf('Error: Packets lost: %d, current frame num = %d \n', (Header.frameNumber - packetNumberPrev - 1), Header.frameNumber)
end
packetNumberPrev = Header.frameNumber;
end
