HDC1080: Compatibility in Vacuum Environment
Part Number: HDC1080
I have a vacuum system which is used to evaporate moisture out of a liquid mixture. I would like to take humidity measurements of the surrounding air in the system to moisture levels. Will the HDC1080 humidity sensor give accurate outputs in environments with air pressure around 0.5 Torr?
