On our MMWAVEICBOOST, the PMIC LP87524J visibly exploded. If we replace this IC with a new LP87524JRNFTQ1, should the board work again (assuming the broken IC is the only problem)? Or does the IC need to be programmed? From the datasheet it seems like the programming is one-time, and done at the factory, but I want to make sure there is no additional programming over I2C necessary.
Tom
