CCS/TIDEP-01012: What are the working principles of various modes about the cascade radar?
Part Number: TIDEP-01012
Other Parts Discussed in Thread: MMWCAS-RF-EVM
1、Is the array used in the MIMO radar mode a sparse array?
2、Does the beamforming mode use digital beamforming or is it similar to phased array work?
  • Hi user6010015,
    Please see the MMWCAS-RF-EVM user guide for a description of the TX/RX antenna patterns and virtual array available on this design. https://www.ti.com/tool/MMWCAS-RF-EVM
    1. The elevation array uses a 4-element minimum redundancy linear array (MRLA) configuration: https://authors.library.caltech.edu/80393/1/01139138.pdf
    The RX array consists of 2x 4-element lambda/2 linear arrays and 1x 8-element lambda/2 linear array. In the azimuth axis this creates up to 144 lambda/2 virtual array elements, but up to 86 unique elements. In elevation, this creates up to 4 MRA elements.
    2. The examples provided show both TX phased array beam-forming/steering and MIMO RX processing across the virtual channel arrays. Digital beam-forming of the resulting IF dataset can be applied, but we do not show an example of this.
    Thank you,
    -Randy
