BOOST-TUSS4470: Question about ID Concentration for TUSS4470
Part Number: BOOST-TUSS4470
I'm considering a purchase of the boost-TUSS4470. My primary application is  ID Concentration in liquids and solids. Why the recommended transducers only have low frequency? None is represented with 1MHz. Doesn't it require to have higher frequency transducer for ID Concentration in solids?
Will Stemnic SMD10T2R111WL work for TUSS4470?
Thank you,
Yana
  • Yana,
    The TUSS4470 can be paired with transducers up to 1MHz, so yes, the Steminc SMD10T2R111WL is compatible for ID concentration measurements. I agree that the BOOSTXL-TUSS4470 is the correct starting tool for your evaluation.
    The recommended transducer list you are referring to is currently specific to the PGA460, and has not yet been expanded to recommend higher frequency transducers that the TUSS4470 can support.
