How can i implement Gesture control and MRR without DCA1000 or 1400 . Is it possible to operate these labs without capture card.
Hi, thank you.
But which software i need to use for uploading all files of any lab, and get the output of the said project?
Each lab includes a user guide that explains how to flash and run the demo
For example, for multi gesture demo please look at the following:
labs\lab0009_multi-gesture-16xx\docs\multi-gesture_16xx_user_guide.pdf
thank you
Cesar
I am unable to change range etc in MRR lab on 1843, which M file i need to edit for range and GUI title edition?
I also do not want to utilize parking assist and USSR in my UI, so from where can i eliminate these two utilities buttons available in GUI.
I want to change its max range and max velocity , how can i update that into GUI?
can you please explain, i could not get your point? Will srr_ti-design___ satisfy my both questions?
If you want to modify the “srr_ti_design_visualization.m” you will be able to update the GUI.
However I am clear what you are trying to achieve. What is the objective of your project?
thank you
Cesar
