From your older thread I understand that you are using AWR1843 devices.
AWR1843 devices can be frame synchronized using hardware trigger. The clock can't be synchronized for these devices. You would need to use AWR1243P or AWR2243 devices if you want to achieve clock synchronization (this is also called cascade. Cascade synchronization is not possible with AWR1843)
thank you
Cesar
