Other Parts Discussed in Thread: AWR1642
I'm using DCA1000EVM with Ti-ARW1642BOOST. I tried to follow the instructions in the mmwave studio user guide but when I tried to "SetUp DCA1000" with my laptop, I received this error message:
GM: Constructor
GM: Wed Sep 16 23:46:51 2020
RSTD.Transmit("/Settings")
[23:46:51]
[23:46:51] ### Running Startup script: "C:\ti\mmwave_studio_02_01_01_00\mmWaveStudio\Scripts\Startup.lua" ###
[23:46:51] RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
[23:46:51] RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
[23:46:51] Scripter ignored: Attempt to UnBuild() again or before Build.
[23:46:51] RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "C:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\Clients\\\\LabClient.dll")
[23:46:51] RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
[23:46:51] RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
[23:46:51] RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
[23:46:51] RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
[23:46:52] RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
[23:46:52] RSTD.SetVar ("/Settings/AL Client/AL Dll" , "C:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\RunTime\\SAL.dll")
[23:46:52] RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
[23:46:52] RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
[23:46:52] RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
[23:46:52] RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
[23:46:52] RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
[23:46:52] RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
[23:46:52] RSTD.Transmit("/")
[23:46:52] RSTD.SaveSettings(): Settings saved to "C:\Users\EECS826\AppData\Roaming\RSTD\config.xml"
[23:46:52] RSTD.Build()
[23:46:52] RSTD.AL_Build()
[23:46:52] RSTD.AL_LoadXml()
[23:46:52] RSTD.AL_Init()
[23:46:52] RSTD.Clients_Build()
[23:46:52] GM: Init
[23:46:52] GM: Loaded 'C:\ti\mmwave_studio_02_01_01_00\mmWaveStudio\Clients\\LabClient.dll'
[23:46:52] GM: 1 Guest (s) init
[23:46:52] GM: 1 Module(s) init
[23:46:52] GM: 2 Tab (s) init
[23:46:52] RSTD.Client_LoadXml()
[23:46:52] [RadarAPI]: ar1.selectRadarMode(0)
[23:46:52] [RadarAPI]: Status: Passed
[23:46:52] Matlab Runtime Engine is installed
[23:46:52] [RadarAPI]: Starting Matlab Engine..
[23:46:57] [RadarAPI]: Matlab Engine Started!
[23:47:00] [RadarAPI]: ar1.selectCascadeMode(0)
[23:47:00] [RadarAPI]: Status: Passed
[23:47:00] [RadarAPI]: ar1.LoadSettings('C:\Users\EECS826\AppData\Roaming\RSTD\ar1gui.ini')
[23:47:01] TESTING = false
[23:47:01] RstdNet: Port 2777: Listening..
[23:47:01]
[23:47:01] ***Script completed successfully.***
[23:47:17] [RadarAPI]: Opening Gpio Control Port()
[23:47:17] [RadarAPI]: Status: Passed
[23:47:18] [RadarAPI]: Opening Board Control Port()
[23:47:18] [RadarAPI]: Status: Passed
[23:47:19] [RadarAPI]: ar1.FullReset()
[23:47:19] [RadarAPI]: Status: Passed
[23:47:20] [RadarAPI]: Closing Board Control Port()
[23:47:20] [RadarAPI]: Status: Passed
[23:47:20] [RadarAPI]: Closing Gpio Control Port()
[23:47:20] [RadarAPI]: ar1.SOPControl(2)
[23:47:37] [RadarAPI]: ar1.Connect(4,921600,1000)
[23:47:39] [RadarAPI]: Warning: Connected with baudrate 115200
[23:47:40] [RadarAPI]: Warning: Disconnected existing BaudRate
[23:47:41] [RadarAPI]: Warning: Trying to connect with baudrate 921600
[23:47:42] [RadarAPI]: ar1.Calling_IsConnected()
[23:47:43] [RadarAPI]: ar1.SelectChipVersion("AR1642")
[23:47:43] [RadarAPI]: Status: Passed
[23:47:43] [RadarAPI]: ar1.deviceVariantSelection("XWR1642")
[23:47:43] [RadarAPI]: ar1.frequencyBandSelection("77G")
[23:47:43] [RadarAPI]: ar1.SelectChipVersion("XWR1642")
[23:47:44] Device Status : XWR1642/ASIL-B/SOP:2/ES:2
[23:47:44] [RadarAPI]: ar1.SaveSettings('C:\Users\EECS826\AppData\Roaming\RSTD\ar1gui.ini')
[23:47:47] [RadarAPI]: ar1.DownloadBSSFw("C:\\ti\\mmwave_studio_02_01_01_00\\rf_eval_firmware\\radarss\\xwr16xx_radarss.bin")
[23:47:47] [RadarAPI]: Downloading BSS Patch RPRC Binary..
[23:47:49] [RadarAPI]: ar1.GetBSSFwVersion()
[23:47:49] [RadarAPI]: BSSFwVersion:(02.00.00.01 (05/10/17))
[23:47:50] [RadarAPI]: ar1.GetBSSPatchFwVersion()
[23:47:50] [RadarAPI]: BSSPatchFwVersion:(01.02.05.02 (30/04/19))
[23:47:51] [RadarAPI]: ar1.DownloadMSSFw("C:\\ti\\mmwave_studio_02_01_01_00\\rf_eval_firmware\\masterss\\xwr16xx_masterss.bin")
[23:47:52] [RadarAPI]: Downloading MSS RPRC Binary..
[23:47:54] [RadarAPI]: ar1.GetMSSFwVersion()
[23:47:54] [RadarAPI]: MSSFwVersion:(01.02.05.02 (16/07/19))
[23:47:56] [RadarAPI]: ar1.PowerOn(0, 1000, 0, 0)
[23:47:56] [RadarAPI]: Status: Passed
[23:47:56] MSS power up done async event received!
[23:47:58] [RadarAPI]: ar1.SelectChipVersion("AR1642")
[23:47:58] [RadarAPI]: Status: Passed
[23:47:58] [RadarAPI]: ar1.SelectChipVersion("XWR1642")
[23:47:58] Device Status : XWR1642/ASIL-B/SOP:2/ES:2
[23:47:58] [RadarAPI]: ar1.RfEnable()
[23:47:59] [RadarAPI]: Status: Passed
[23:47:59] BSS power up done async event received!
[23:47:59] [RadarAPI]: ar1.GetMSSFwVersion()
[23:47:59] [RadarAPI]: MSSFwVersion:(01.02.05.02 (16/07/19))
[23:47:59] [RadarAPI]: ar1.GetBSSFwVersion()
[23:48:00] [RadarAPI]: BSSFwVersion:(02.00.00.01 (05/10/17))
[23:48:00] [RadarAPI]: ar1.GetBSSPatchFwVersion()
[23:48:00] [RadarAPI]: BSSPatchFwVersion:(01.02.05.02 (30/04/19))
[23:48:08] [RadarAPI]: ar1.ChanNAdcConfig(1, 1, 0, 1, 1, 1, 1, 2, 1, 0)
[23:48:08] [RadarAPI]: Status: Passed
[23:48:10] [RadarAPI]: ar1.LPModConfig(0, 0)
[23:48:10] [RadarAPI]: Status: Failed, Error Type: REGULAR ADC MODE NOT SUPPORTED IN 5 MHz PART VARIANT DEVICE
[23:48:11] [RadarAPI]: ar1.RfInit()
[23:48:11] [RadarAPI]: Status: Passed
[23:48:11] RF Init async event received!
[23:48:11] [RadarAPI]: Time stamp, Temperture: 12740,39; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 0, 0; RxIQMM Status, Update: 1, 1;
[23:48:13] [RadarAPI]: ar1.SetCalMonFreqLimitConfig(77,81)
[23:48:13] [RadarAPI]: Status: Passed
[23:48:17] [RadarAPI]: ar1.DataPathConfig(513, 1216644097, 0)
[23:48:17] [RadarAPI]: Status: Passed
[23:48:18] [RadarAPI]: ar1.LvdsClkConfig(1, 1)
[23:48:18] [RadarAPI]: Status: Passed
[23:48:19] [RadarAPI]: ar1.LVDSLaneConfig(0, 1, 1, 0, 0, 1, 0, 0)
[23:48:19] [RadarAPI]: Status: Passed
[23:48:29] [RadarAPI]: ar1.ProfileConfig(0, 77, 100, 6, 60, 0, 0, 0, 0, 0, 0, 29.982, 0, 256, 6000, 0, 0, 30)
[23:48:29] [RadarAPI]: Status: Passed
[23:48:30] [RadarAPI]: ar1.ChirpConfig(0, 0, 0, 0, 0, 0, 0, 1, 0, 0)
[23:48:30] [RadarAPI]: Status: Passed
[23:48:31] Test Source Already Disabled...!!!
[23:48:31] [RadarAPI]: ar1.DisableTestSource(0)
[23:48:31] [RadarAPI]: Status: Passed
[23:48:31] [RadarAPI]: ar1.FrameConfig(0, 0, 8, 128, 40, 0, 0, 1)
[23:48:35] [RadarAPI]: ar1.GetCaptureCardDllVersion()
[23:48:35] [RadarAPI]: Sending dll_version command to DCA1000
[23:48:35] DLL Version : 1.0
[23:48:35] [RadarAPI]: ar1.SelectCaptureDevice("DCA1000")
[23:48:35] [RadarAPI]: Status: Passed
[23:48:37] [RadarAPI]: ar1.CaptureCardConfig_EthInit("192.168.33.30", "192.168.33.180", "12:34:56:78:90:12", 4096, 4098)
[23:48:37] [RadarAPI]: ar1.CaptureCardConfig_Mode(1, 2, 1, 2, 3, 30)
[23:48:37] [RadarAPI]: ar1.CaptureCardConfig_PacketDelay(25)
[23:48:37] [RadarAPI]: Sending fpga command to DCA1000
[23:48:47] [RadarAPI]:
[23:48:47] FPGA Configuration :
[23:48:47] Timeout Error! System disconnected
[23:48:47] [RadarAPI]: Sending record command to DCA1000
[23:48:58] [RadarAPI]:
[23:48:58] Configure Record :
[23:48:58] Timeout Error! System disconnected
[23:48:58] [RadarAPI]: ar1.GetCaptureCardFPGAVersion()
[23:48:58] [RadarAPI]: Sending fpga_version command to DCA1000
[23:49:08] [RadarAPI]:
[23:49:08]
[23:49:08] Unable to read FPGA Version. [error -5]
[23:49:08]
[23:49:16] [RadarAPI]: ar1.GetCaptureCardDllVersion()
[23:49:16] [RadarAPI]: Sending dll_version command to DCA1000
[23:49:16] DLL Version : 1.0
[23:49:16] [RadarAPI]: ar1.SelectCaptureDevice("DCA1000")
[23:49:16] [RadarAPI]: Status: Passed
[23:49:18] [RadarAPI]: ar1.CaptureCardConfig_EthInit("192.168.33.30", "192.168.33.180", "12:34:56:78:90:12", 4096, 4098)
[23:49:18] [RadarAPI]: ar1.CaptureCardConfig_Mode(1, 2, 1, 2, 3, 30)
[23:49:18] [RadarAPI]: ar1.CaptureCardConfig_PacketDelay(25)
[23:49:18] [RadarAPI]: Sending fpga command to DCA1000
[23:49:21] [RadarAPI]: ar1.CaptureCardConfig_EthInit("192.168.33.30", "192.168.33.180", "12:34:56:78:90:12", 4096, 4098)
[23:49:21] [RadarAPI]: ar1.CaptureCardConfig_Mode(1, 2, 1, 2, 3, 30)
[23:49:21] [RadarAPI]: ar1.CaptureCardConfig_PacketDelay(25)
[23:49:21] [RadarAPI]: Sending fpga command to DCA1000
[23:49:21]
[23:49:21] ConnectRFDCCard_ConfigMode(): Bind failed (Config port) : 10048
[23:49:21] Ethernet connection failed. [error -4051]
[23:49:21] [RadarAPI]: Sending record command to DCA1000
[23:49:21]
[23:49:21] [RadarAPI]: ar1.GetCaptureCardFPGAVersion()
[23:49:21] [RadarAPI]: Sending fpga_version command to DCA1000
[23:49:22] [RadarAPI]:
[23:49:22]
[23:49:22] ConnectRFDCCard_ConfigMode(): Bind failed (Config port) : 10048
[23:49:22] Ethernet connection failed. [error -4051]
[23:49:22] [RadarAPI]: ar1.CaptureCardConfig_EthInit("192.168.33.30", "192.168.33.180", "12:34:56:78:90:12", 4096, 4098)
[23:49:22] [RadarAPI]: ar1.CaptureCardConfig_Mode(1, 2, 1, 2, 3, 30)
[23:49:22] [RadarAPI]: ar1.CaptureCardConfig_PacketDelay(25)
[23:49:22] [RadarAPI]: Sending fpga command to DCA1000
[23:49:22]
[23:49:22] [RadarAPI]: Sending record command to DCA1000
[23:49:22]
[23:49:22] [RadarAPI]: ar1.GetCaptureCardFPGAVersion()
[23:49:22] [RadarAPI]: Sending fpga_version command to DCA1000
[23:49:22]
[23:49:22]
[23:49:22]
[23:49:22]
[23:49:22]
[23:49:22]
[23:49:22]
[23:49:23] [RadarAPI]:
[23:49:23]
[23:49:23] ConnectRFDCCard_ConfigMode(): Bind failed (Config port) : 10048
[23:49:23] Ethernet connection failed. [error -4051]
[23:49:23]
[23:49:23] [RadarAPI]: ar1.GetCaptureCardFPGAVersion()
[23:49:23] [RadarAPI]: Sending fpga_version command to DCA1000
[23:49:23]
[23:49:23] [RadarAPI]: Sending record command to DCA1000
[23:49:23]
[23:49:23] [RadarAPI]: ar1.CaptureCardConfig_EthInit("192.168.33.30", "192.168.33.180", "12:34:56:78:90:12", 4096, 4098)
[23:49:23] [RadarAPI]: ar1.CaptureCardConfig_Mode(1, 2, 1, 2, 3, 30)
[23:49:23]
[23:49:23] [RadarAPI]: ar1.CaptureCardConfig_PacketDelay(25)
[23:49:23] [RadarAPI]: Sending fpga command to DCA1000
[23:49:23]
[23:49:23]
[23:49:23]
[23:49:23]
[23:49:23]
[23:49:23]
[23:49:23]
[23:49:29] [RadarAPI]:
[23:49:29] FPGA Configuration :
[23:49:29] Timeout Error! System disconnected
[23:49:29] [RadarAPI]: Sending record command to DCA1000
[23:49:39] [RadarAPI]:
[23:49:39] Configure Record :
[23:49:39] Timeout Error! System disconnected
[23:49:39] [RadarAPI]: ar1.GetCaptureCardFPGAVersion()
[23:49:39] [RadarAPI]: Sending fpga_version command to DCA1000
[23:49:49] [RadarAPI]:
[23:49:49]
[23:49:49] Unable to read FPGA Version. [error -5]
Strangely, it runs well when I tried the same operation on a desktop.
How can I solve this problem?
Leah
