IWR6843ISK: order of doppler chirps to be supplied to doppler computation
Part Number: IWR6843ISK
Hello support team,
According to below doppler DPU, data processing is started with Tx0-Rx1 and Tx1-Rx1 as 1st iretation and Tx0-Rx2 and Tx1-Rx2 is supplied as 2nd iretation.
C:\ti\mmwave_sdk_03_03_00_03\packages\ti\datapath\dpc\dpu\dopplerproc\docs\doxygen\html\index.html
I suppose it is not necessary to mofiy the order of doppler chirps to be supplied to the data processing, regardless of antenna array.
Am I right ? I appreciate any of your advice.
(Actually I am concerned about our original antenna design, as discussed https://e2e.ti.com/support/sensors/f/1023/p/916460/3409875#3409875 .)
Taka
  • Hi Taka-san,
    The order of received symbols depends upon the transmit order and the ordering is important for the angle of arrival functionality to work correctly. If you are not changing the TX order (i.e. the chirp to TX antenna association in the chirpCfg commands), the Doppler chirp order will not change i.e. you do not need to modify the order.
    -Nitin
  • 4428.MIMO_config.xlsx
    Hello Nitin,
    Yes. I have modifed data order before RX phase compensation block in AOA DPU, depending on virtual antenna array in our original design.
    I appreciate if you can advise correct doppler chirp order (=ping/pong pattern) for attached antenna array.
    Taka
  • Hello Taka-san,
    It is not clear why you need to modify the order of symbols before the RX phase compensation in AoA DPU? Could you please clarify?
    -Nitin
  • For the purpose of estimating doppler and generating the detection matrix, the order of Tx-Rx pairs in the processing does not matter, each pair will produce the same doppler estimates but we do all pairs to accumulate the energies (sum of log abs) of all pairs to improve the SNR for detection. We are doing what is non-coherent combining here.
  • Hello Piyush, Nitin,
    Thank you for your reply. I understand the order of Tx-Rx pairs basically does not matter but it may be better to choose non-coherent pairs.
    Best regadrs,
    Taka
