IWR6843: The problem of serial port setting check digit
Part Number: IWR6843
Hi Team,
Due to the serial protocol requirements, customer needs to switch the parity bit when receiving data. He would like to know how to modify the parity bit through the configuration register?
Annie
  • Hello
    Have you had a look at the technical reference manual which explains the register level details of the peripherals.
    You may be able to use the parity setting there to achieve the required results.  Please look and let us know so that we can help with more details.
    Thank you,
    Vaibhav
