AWR1642BOOST: original flash-binary of the AWR1642BOOST
Part Number: AWR1642BOOST
I have one unit of the AWR1642BOOST and I changed the factory flashed binary by the one from the SRR lab. Now I need to reflash with the original one to use it with the TI web interface. Where can I get this default flashed binary?
Thanks in advance.
  • The original binary flashed on the EVM is the mmWave SDK demo.
    It is provided in the mmWave SDK release
    You can download the latest release from
    Thank you
    Cesar
  • Thank you. I would also appreciate if you could be a little more specific. This is the list of *.bin files. Would you point out which one was it?
    ./mmwave_sdk_03_05_00_04/firmware/radarss/xwr18xx_radarss_rprc.bin
    ./mmwave_sdk_03_05_00_04/firmware/radarss/xwr12xx_xwr14xx_radarss_rprc.bin
    ./mmwave_sdk_03_05_00_04/firmware/radarss/xwr16xx_radarss_rprc.bin
    ./mmwave_sdk_03_05_00_04/firmware/radarss/xwr6xxx_radarss_rprc.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/utils/ccsdebug/xwr18xx_ccsdebug.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/utils/ccsdebug/xwr68xx_ccsdebug.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/utils/ccsdebug/xwr14xx_ccsdebug.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/utils/ccsdebug/xwr16xx_ccsdebug.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/utils/ccsdebug/xwr64xx_ccsdebug.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/utils/sbl/xwr68xx_sbl.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/utils/sbl/xwr16xx_sbl.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/utils/sbl/xwr18xx_sbl.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/demo/xwr16xx/mmw/xwr16xx_mmw_demo.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/demo/xwr68xx/mmw/xwr68xx_mmw_demo.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/demo/xwr64xx/mmw/xwr64xx_mmw_demo.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/demo/xwr64xx/mmw/xwr64xxAOP_mmw_demo.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/demo/xwr18xx/mmw/xwr18xx_mmw_demo.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/demo/xwr18xx/mmw/xwr18xx_mmw_aop_demo.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/demo/xwr18xx/mmw/xwr18xx_mmw_aop_demo_secure.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/datapath/dpc/objectdetection/objdetdsp/test/testdata/xwr68xx_data_path_test_config.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/datapath/dpc/objectdetection/objdetdsp/test/testdata/xwr18xx_data_path_test_config.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/datapath/dpc/objectdetection/objdetdsp/test/testdata/xwr16xx_data_path_test_config.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/datapath/dpc/objectdetection/objdethwa/test/testdata/xwr68xx_stdevm_dss_data_path_test_config.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/datapath/dpc/objectdetection/objdethwa/test/testdata/xwr18xx_aopevm_mss_data_path_test_config.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/datapath/dpc/objectdetection/objdethwa/test/testdata/xwr68xx_aopevm_dss_data_path_test_config.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/datapath/dpc/objectdetection/objdethwa/test/testdata/xwr18xx_stdevm_mss_data_path_test_config.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/datapath/dpc/objectdetection/objdethwa/test/testdata/xwr18xx_stdevm_dss_data_path_test_config.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/datapath/dpc/objectdetection/objdethwa/test/testdata/xwr68xx_stdevm_mss_data_path_test_config.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/datapath/dpc/objectdetection/objdethwa/test/testdata/xwr18xx_aopevm_dss_data_path_test_config.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/datapath/dpc/objectdetection/objdethwa/test/testdata/xwr68xx_aopevm_mss_data_path_test_config.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/datapath/dpc/dpu/cfarcaproc/test/testdata/cfardpu_test_data.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/datapath/dpu/rangeproc/test/testdata/rangeprochwa_test_data.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/datapath/dpu/rangeproc/test/testdata/rangeprocdsp_test_data.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/alg/gtrack/test/vectors/usecases/people_counting/fHistScene4_2d_0001.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/alg/gtrack/test/vectors/usecases/people_counting/fHistScene4_3d_0001.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/alg/mmwavelib/test/testdata/floatpoint_test_dbscanCluster_ref.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/alg/mmwavelib/test/testdata/dftsinglebin_test.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/alg/mmwavelib/test/testdata/clustering_test.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/alg/mmwavelib/test/testdata/radarDemo_captured_test.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/alg/mmwavelib/test/testdata/dftsinglebinwithwin_test.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/alg/mmwavelib/test/testdata/floatpoint_test_dbscanCluster.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/alg/mmwavelib/test/testdata/radarDemo_multiObj_test.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/alg/mmwavelib/test/testdata/windowFlt_test.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/alg/mmwavelib/test/testdata/accumPowerFlt_test.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/alg/mmwavelib/test/testdata/dftsinglebinwithwinQI_test.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/alg/mmwavelib/test/testdata/peakpruning_test.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/alg/mmwavelib/test/testdata/floatPoint_chain_test.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/alg/mmwavelib/test/testdata/radarDemo_multiObj_ref.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/alg/mmwavelib/test/testdata/radarDemo_captured_ref.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/alg/mmwavelib/test/testdata/cfarca_wrap_test.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/alg/mmwavelib/test/testdata/aoaest_test.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/alg/mmwavelib/test/testdata/cfarca_test.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/alg/mmwavelib/test/testdata/floatpoint_test_aoaMultiObj_ref.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/alg/mmwavelib/test/testdata/floatpoint_test_aoaMultiObj.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/alg/mmwavelib/test/testdata/radarDemo_ref_new.bin
    ./mmwave_sdk_03_05_00_04/packages/ti/alg/mmwavelib/test/testdata/cfarca_peak_test.bin
    The mmWave SDK User Guide provides information 3.2.1
    C:\ti\mmwave_sdk_03_05_00_01\docs\mmwave_sdk_user_guide.pdf
    Thank you
    Cesar
