Part Number: AWR1443BOOST
Other Parts Discussed in Thread: AWR1443
Hello Sir,
We are collecting radar raw data with AWR1443 boost and sending data over uart to PC. In the application we are performing 1D FFT, 2FFT ,CFAR and extracting raw data using range index and doppler index using cfarobjptr. In the cfar configuration command the threshold scale is set to 1200. So could you please help us to solve following queries:-
1) How the cfar works with the threshold scale?
2) Is there any chances of identifying a CUT as detected object if the peak value of CUT is below the threshold scale set in cfar configuration command?
3) How is the comparison of threshold and peak value of CUT is done?
Thanks and regards
KK
