IWR6843AOPEVM: About TI mmWave ROS Driver demo
Guru 10235 points
Part Number: IWR6843AOPEVM
Other Parts Discussed in Thread: IWR6843AOP, MMWAVEICBOOST
Hello, TI Experts,
We tried to run TI mmWave ROS Driver demo like below with IWR6843AOP(ES2.0).
http://dev.ti.com/tirex/explore/node?node=AOVWxEvg-HcESecamNaaLg__VLyFKFf__LATEST
I can run success the demo with IWR6843AOP(ES2.0) & MMWAVEICBOOST.
Then I can also success to run with only IWR6843AOP(ES2.0) by modifying USB setting like below.
file:
ti_mmwave_rospkg/launch/6843AOP_multi_3d_0.launch
[before]
     <param name="command_port" value="/dev/ttyACM0" />
     <param name="data_port" value="/dev/ttyACM1" />
[after]
   <param name="command_port" value="/dev/ttyUSB0" />
   <param name="data_port" value="/dev/ttyUSB1" />
Question:
Is it proper way to use this TI mmWave ROS Driver demo with only IWR6843AOP(ES2.0)?
If there are any comment or recommended way, please tell us.
