Hi all,
I try to porting our people_count project from CLI to hard code config. I refer to your 68xx_mmwave_sdk_hcc and edit out project, After porting the project, it cannot work correctly. I enter debug mode and "out of DDR heap memory" in console. Please give me some suggestions to solve this problem. Thank you
I provide my program and information for your reference
console information
[C674X_0] ObjDet DPC: objDetObj address = (ObjDetObj *) 0x81dfb0
Debug: DPM Module Sync is done
[Cortex_R4_0] **********************************************
Debug: Launching the MMW Demo on MSS
Debug: Launched the Initialization Task
Debug: mmWave Control Initialization was successful
Debug: mmWave Control Synchronization was successful
Debug: Sending rlRfSetLdoBypassConfig with 0 0 0
Sensor was successfully opened.
Data Output Mode: Frame
Sending configSensor command to EVM.
App: Issuing Pre-start Common Config IOCTL to R4F
App: Issuing Pre-start Common Config IOCTL to DSP
DPM IOCTL report msg = 101
DPM IOCTL report msg = 201
App: Calling MmwDemo_RFParser_parseConfig
App: Calling MmwDemo_ADCBufConfig
============ Heap Memory Stats ============
Size Used Free DPCUsed
System Heap(TCMB) 133120 38864 94256 3072
L3 589824 393216 196608
localRam(TCMB) 8192 512 7680
DPM IOCTL report msg = 200
App: pre-start config for DSP
App: pre-start config ready to be set to DSP
[C674X_0] out of DDR heap memory!
out of L2 heap memory!
DPU_radarProcess_init - process handle: (radarProcessInstance_t *)0xf01200
DPU_radarProcess_init - dynamic CFAR handle: (RADARDEMO_detectionCFAR_handle *)0x0
DPU_radarProcess_init - staic CFAR handle: (RADARDEMO_detectionCFAR_handle *)0x7f0820
DPU_radarProcess_init - 2D capon handle: (RADARDEMO_aoaEst2DCaponBF_handle *)0xf01690
DPU_radarProcess_init - benchmark obj: (radarProcessBenchmarkObj *)0x0
DPU_radarProcess_init - heatmap: (float *)0x0
