Other Parts Discussed in Thread: TDC7200, , BOOSTXL-PGA460, PGA460, TDC1000
I am building an ultrasonic thickness gauge to measure the thickness of metals.
I am going to use TDC1011 Analog Front End IC, along with TDC7200 Time to Digital Converter, to get the time difference between the 2 reflected echos.
I want to use a disc-shaped Piezo Sensor, which has an axial resonant frequency of about 4Mhz.
I wanted to know if there are any specific Piezo to be used(Company from where I can buy online), which would give me the best result on using with the TDC1011 IC.
Also, wanted to know which Piezo Sensor did the Texas Instrument used while creating its datasheet because the datasheet results are based on the Piezo Sensor, which has a resonant frequency of 4MHz.
I really appreciate any help you can provide.
