Other Parts Discussed in Thread: AWR2243, AWR1243, TDA2
My customer is working on TI AWR2243 cascaded EVM with processor sdk for radar v3.08 and now after modified the sdk, the mimo use case (a: Cascade Radar (4 AWR1243) Capture + Radar Object Detect (DSP) + NetworkTx (TDA2xx Only)) can work ok.
But customer found if he runs the mimo case, then select 0 to stop chain. Then try to run the mimo case again, he will meet below error.
[IPU1-0] 232.966662 s: AR12XX: Firmware Download Started : Ftype: BSS_BUILD
[IPU1-0] 233.038156 s: AR12XX: Firmware chunk No. 50 download Failed : Ftype: BSS_BUILD
[IPU1-0] 233.038248 s: Assertion @ Line: 280 in C:/PROCESSOR_SDK_RADAR_03_08/vision_sdk/apps/src/rtos/radar/src/common/chains_common_ar12xx.c: SYSTEM_LINK_STATUS_SOK == retVal : failed !!!
Customer added more print in the code when problem happened. Pls check below.
[IPU1-0] 57.958610 s: AR12XX: Firmware Download Started : Ftype: BSS_BUILD
[IPU1-0] 57.960989 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 57.961080 s: 0001AWR12XX: Bsp_ar12xxFmwSectionDwld = 0
[IPU1-0] 57.963551 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 57.965686 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 57.968035 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 57.970444 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 57.972915 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 57.975080 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 57.977734 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 57.979869 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 57.981974 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 57.984627 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 57.986732 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 57.989141 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 57.991551 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 57.993960 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 57.996095 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 57.998810 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.000976 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.003141 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.005551 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.007625 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.009973 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.012047 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.014121 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.016500 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.018605 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.020923 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.022997 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.025071 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.027450 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.029555 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.031873 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.033947 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.035990 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.038370 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.040474 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.042823 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.044866 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.046940 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.049289 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.051393 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.053772 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.055847 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.057890 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.060239 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.062343 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.064722 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.066796 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.068840 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = 0
[IPU1-0] 58.071249 s: 00000AWR12XX: Bsp_ar12xxFmwChunkDwld = -10
[IPU1-0] 58.071371 s: AR12XX: Firmware chunk No. 50 download Failed : Ftype: BSS_BUILD
[IPU1-0] 58.071493 s: 0002AWR12XX: Bsp_ar12xxFmwSectionDwld = -10
[IPU1-0] 58.071585 s: 0003AWR12XX: Bsp_ar12xxFmwSectionDwld = -10
[IPU1-0] 58.071676 s: 003AWR12XX: Bsp_ar12xxFmwSpiDwld = -10
[IPU1-0] 58.071768 s: 01AWR12XX: Bsp_ar12xxBoot = -10
[IPU1-0] 58.071859 s: 02AWR12XX: Bsp_ar12xxBoot = -10
[IPU1-0] 58.071951 s: 07AWR12XX: Bsp_ar12xxBoot = -10
[IPU1-0] 58.072042 s: 08AWR12XX: Bsp_ar12xxBoot = -10
[IPU1-0] 58.072103 s: Assertion @ Line: 282 in D:/ti/PROCESSOR_SDK_RADAR_03_08_00_00/radar_app_base_cascade/apps/src/rtos/radar/src/common/chains_common_ar12xx.c: SYSTEM_LINK_STATUS_SOK == retVal : failed !!
I found after stop chain, the DS4/5/6/7 LED on RF board will be off. That means that the nreset is low. When re-run the use case and the firmware is downloading, the DS4 will be on. That means the master chip is out of nreset. But the firmware downloading is still failed.
Would you pls kindly help to solve this problem?
