I want to continue this question : https://e2e.ti.com/support/sensors/f/1023/t/968388
without changing PCB and without SOP settings:
Can you suggest which one is working exactly same as the parts MX25R1635FZUIH0?
We just order different parts using the same PCB provided by TI.
Any of the SFLASH in the reference app note should work. You need to confirm from Macronix which of the IC on the list is pin for pin compatible with your design.
https://www.ti.com/lit/an/sprach9b/sprach9b.pdf
Charles O
