Other Parts Discussed in Thread: DCA1000EVM, , AWR1843
output :
GM: Constructor
GM: Thu Jan 28 20:25:16 2021
RSTD.Transmit("/Settings")
[20:25:16]
[20:25:16] ### Running Startup script: "C:\ti\mmwave_studio_02_01_01_00\mmWaveStudio\Scripts\Startup.lua" ###
[20:25:16] RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
[20:25:16] RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
[20:25:16] Scripter ignored: Attempt to UnBuild() again or before Build.
[20:25:16] RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "C:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\Clients\\\\LabClient.dll")
[20:25:16] RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
[20:25:16] RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
[20:25:16] RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
[20:25:16] RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
[20:25:16] RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
[20:25:16] RSTD.SetVar ("/Settings/AL Client/AL Dll" , "C:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\RunTime\\SAL.dll")
[20:25:16] RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
[20:25:16] RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
[20:25:16] RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
[20:25:16] RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
[20:25:16] RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
[20:25:16] RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
[20:25:16] RSTD.Transmit("/")
[20:25:16] RSTD.SaveSettings(): Settings saved to "C:\Users\royn.CAT\AppData\Roaming\RSTD\config.xml"
[20:25:17] RSTD.Build()
[20:25:17] RSTD.SaveSettings(): Settings saved to "C:\Users\royn.CAT\AppData\Roaming\RSTD\config.xml"
[20:25:17] RSTD.Transmit("/")
[20:25:17] RSTD.AL_Build()
[20:25:17] RSTD.AL_LoadXml()
[20:25:17] RSTD.AL_Init()
[20:25:17] RSTD.Clients_Build()
[20:25:17] GM: Init
[20:25:17] GM: Loaded 'C:\ti\mmwave_studio_02_01_01_00\mmWaveStudio\Clients\\LabClient.dll'
[20:25:17] GM: 1 Guest (s) init
[20:25:17] GM: 1 Module(s) init
[20:25:17] GM: 2 Tab (s) init
[20:25:17] RSTD.Client_LoadXml()
[20:25:17] [RadarAPI]: ar1.selectRadarMode(0)
[20:25:17] [RadarAPI]: Status: Passed
[20:25:17] Matlab Runtime Engine is installed
[20:25:17] [RadarAPI]: Starting Matlab Engine..
[20:25:40] [RadarAPI]: Matlab Engine Started!
[20:25:42] [RadarAPI]: ar1.selectCascadeMode(0)
[20:25:42] [RadarAPI]: Status: Passed
[20:25:42] [RadarAPI]: ar1.LoadSettings('C:\Users\royn.CAT\AppData\Roaming\RSTD\ar1gui.ini')
[20:25:42] TESTING = false
[20:25:42] RstdNet: Port 2777: Listening..
[20:25:42]
[20:25:42] ***Script completed successfully.***
[20:26:08] [RadarAPI]: Opening Gpio Control Port()
[20:26:08] [RadarAPI]: Status: Passed
[20:26:09] [RadarAPI]: Opening Board Control Port()
[20:26:09] [RadarAPI]: Status: Passed
[20:26:10] [RadarAPI]: ar1.FullReset()
[20:26:10] [RadarAPI]: Status: Passed
[20:26:11] [RadarAPI]: Closing Board Control Port()
[20:26:11] [RadarAPI]: Status: Passed
[20:26:11] [RadarAPI]: Closing Gpio Control Port()
[20:26:11] [RadarAPI]: ar1.SOPControl(2)
[20:29:49] [RadarAPI]: ar1.SelectCaptureDevice("DCA1000")
[20:29:49] [RadarAPI]: Status: Passed
[20:30:03]
[20:30:03] Lua Error:
[20:30:03] Input string was not in a correct format.
[20:30:30] [RadarAPI]: ar1.Connect(4,921600,1000)
[20:30:33] [RadarAPI]: Warning: Connected with baudrate 115200
[20:30:34] [RadarAPI]: Warning: Disconnected existing BaudRate
[20:30:34] [RadarAPI]: Warning: Trying to connect with baudrate 921600
[20:30:36] [RadarAPI]: ar1.Calling_IsConnected()
[20:30:37] [RadarAPI]: ar1.SelectChipVersion("AR1642")
[20:30:37] [RadarAPI]: Status: Passed
[20:30:37] [RadarAPI]: ar1.deviceVariantSelection("XWR1843")
[20:30:37] [RadarAPI]: ar1.frequencyBandSelection("77G")
[20:30:37] [RadarAPI]: ar1.SelectChipVersion("XWR1843")
[20:30:37] Device Status : XWR1843/ASIL-B/SOP:2/ES:2
[20:30:37] [RadarAPI]: ar1.SaveSettings('C:\Users\royn.CAT\AppData\Roaming\RSTD\ar1gui.ini')
[20:30:50] [RadarAPI]: ar1.DownloadBSSFw("C:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\Scripts\\..\\..\\rf_eval_firmware\\radarss\\xwr18xx_radarss.bin")
[20:30:51] [RadarAPI]: Downloading BSS Patch RPRC Binary..
[20:30:52] [RadarAPI]: ar1.GetBSSFwVersion()
[20:30:52] [RadarAPI]: BSSFwVersion:(02.00.00.01 (05/10/17))
[20:30:53] [RadarAPI]: ar1.GetBSSPatchFwVersion()
[20:30:53] [RadarAPI]: BSSPatchFwVersion:(01.02.05.02 (30/04/19))
[20:30:56] [RadarAPI]: ar1.DownloadMSSFw("C:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\Scripts\\..\\..\\rf_eval_firmware\\masterss\\xwr18xx_masterss.bin")
[20:30:56] [RadarAPI]: Downloading MSS RPRC Binary..
[20:30:58] [RadarAPI]: ar1.GetMSSFwVersion()
[20:30:58] [RadarAPI]: MSSFwVersion:(01.02.05.02 (16/07/19))
[20:31:03] [RadarAPI]: ar1.PowerOn(0, 1000, 0, 0)
[20:31:03] [RadarAPI]: Status: Passed
[20:31:03] MSS power up done async event received!
[20:35:37] [RadarAPI]: ar1.SelectChipVersion("AR1642")
[20:35:37] [RadarAPI]: Status: Passed
[20:35:37] [RadarAPI]: ar1.SelectChipVersion("XWR1843")
[20:35:37] Device Status : XWR1843/ASIL-B/SOP:2/ES:2
[20:35:37] [RadarAPI]: ar1.RfEnable()
[20:35:37] BSS power up done async event received!
[20:35:37] [RadarAPI]: ar1.GetMSSFwVersion()
[20:35:37] [RadarAPI]: MSSFwVersion:(01.02.05.02 (16/07/19))
[20:35:38] [RadarAPI]: ar1.GetBSSFwVersion()
[20:35:38] [RadarAPI]: BSSFwVersion:(02.00.00.01 (05/10/17))
[20:35:39] [RadarAPI]: ar1.GetBSSPatchFwVersion()
[20:35:39] [RadarAPI]: BSSPatchFwVersion:(01.02.05.02 (30/04/19))
