Other Parts Discussed in Thread: DCA1000EVM
GM: Constructor GM: Wed Feb 24 17:56:17 2021 RSTD.Transmit("/Settings") [17:56:18] [17:56:18] ### Running Startup script: "C:\ti\mmwave_studio_02_01_01_00\mmWaveStudio\Scripts\Startup.lua" ### [17:56:18] RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1") [17:56:18] RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss") [17:56:18] Scripter ignored: Attempt to UnBuild() again or before Build. [17:56:18] RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "C:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\Clients\\\\LabClient.dll") [17:56:18] RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE") [17:56:18] RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE") [17:56:18] RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE") [17:56:18] RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE") [17:56:18] RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE") [17:56:18] RSTD.SetVar ("/Settings/AL Client/AL Dll" , "C:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\RunTime\\SAL.dll") [17:56:18] RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "") [17:56:18] RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE") [17:56:18] RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1") [17:56:18] RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE") [17:56:18] RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE") [17:56:18] RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false") [17:56:18] RSTD.Transmit("/") [17:56:18] RSTD.SaveSettings(): Settings saved to "C:\Users\0000100139\AppData\Roaming\RSTD\config.xml" [17:56:18] RSTD.Build() [17:56:18] RSTD.SaveSettings(): Settings saved to "C:\Users\0000100139\AppData\Roaming\RSTD\config.xml" [17:56:18] RSTD.Transmit("/") [17:56:18] RSTD.AL_Build() [17:56:18] RSTD.AL_LoadXml() [17:56:18] RSTD.Transmit("/") [17:56:18] RSTD.AL_Init() [17:56:18] RSTD.Clients_Build() [17:56:18] GM: Init [17:56:18] GM: Loaded 'C:\ti\mmwave_studio_02_01_01_00\mmWaveStudio\Clients\\LabClient.dll' [17:56:18] GM: 1 Guest (s) init [17:56:18] GM: 1 Module(s) init [17:56:18] GM: 2 Tab (s) init [17:56:18] RSTD.Client_LoadXml() [17:56:18] [RadarAPI]: ar1.selectRadarMode(0) [17:56:18] [RadarAPI]: Status: Passed [17:56:18] Matlab Runtime Engine is installed [17:56:18] [RadarAPI]: Starting Matlab Engine.. [17:56:23] [RadarAPI]: Matlab Engine Started! [17:56:25] [RadarAPI]: ar1.selectCascadeMode(0) [17:56:25] [RadarAPI]: Status: Passed [17:56:25] [RadarAPI]: ar1.LoadSettings('C:\Users\0000100139\AppData\Roaming\RSTD\ar1gui.ini') [17:56:25] TESTING = false [17:56:25] RstdNet: Port 2777: Listening.. [17:56:25] [17:56:25] ***Script completed successfully.*** [17:56:47] [RadarAPI]: Opening Gpio Control Port() [17:56:47] [RadarAPI]: Status: Passed [17:56:47] [RadarAPI]: Opening Board Control Port() [17:56:47] [RadarAPI]: Status: Passed [17:56:48] [RadarAPI]: ar1.FullReset() [17:56:48] [RadarAPI]: Status: Passed [17:56:49] [RadarAPI]: Closing Board Control Port() [17:56:49] [RadarAPI]: Status: Passed [17:56:49] [RadarAPI]: Closing Gpio Control Port() [17:56:49] [RadarAPI]: Status: Passed [17:56:49] [RadarAPI]: ar1.SOPControl(2) [17:56:49] [RadarAPI]: Status: Passed [17:56:51] [RadarAPI]: ar1.Connect(1,921600,1000) [17:56:53] [RadarAPI]: Warning: Connected with baudrate 115200 [17:56:54] [RadarAPI]: Warning: Disconnected existing BaudRate [17:56:55] [RadarAPI]: Warning: Trying to connect with baudrate 921600 [17:56:56] [RadarAPI]: ar1.Calling_IsConnected() [17:56:57] [RadarAPI]: ar1.SelectChipVersion("IWR6843") [17:56:57] [RadarAPI]: Status: Passed [17:56:57] [RadarAPI]: ar1.frequencyBandSelection("60G") [17:56:57] [RadarAPI]: ar1.SelectChipVersion("IWR6843") [17:56:57] [RadarAPI]: Status: Passed [17:56:58] Device Status : IWR6843/QM/SOP:2/ES:2 [17:56:58] [RadarAPI]: ar1.SaveSettings('C:\Users\0000100139\AppData\Roaming\RSTD\ar1gui.ini') [17:56:59] [RadarAPI]: ar1.DownloadBSSFw("C:\\ti\\mmwave_sdk_03_04_00_03\\mmwave_sdk_03_04_00_03\\firmware\\radarss\\xwr6xxx_radarss_rprc.bin") [17:57:00] [RadarAPI]: Downloading BSS ROM RPRC Binary.. [17:57:07] [RadarAPI]: ar1.GetBSSFwVersion() [17:57:07] [RadarAPI]: BSSFwVersion:(06.02.01.05 (09/03/20)) [17:57:08] [RadarAPI]: ar1.DownloadMSSFw("C:\\ti\\mmwave_studio_02_01_01_00\\rf_eval_firmware\\masterss\\xwr68xx_masterss.bin") [17:57:08] [RadarAPI]: Downloading MSS RPRC Binary.. [17:57:11] [RadarAPI]: ar1.GetMSSFwVersion() [17:57:11] [RadarAPI]: MSSFwVersion:(02.00.00.03 (27/08/19)) [17:57:13] [RadarAPI]: ar1.PowerOn(0, 1000, 0, 0) [17:57:13] [RadarAPI]: Status: Passed [17:57:13] MSS power up done async event received! [17:57:15] [RadarAPI]: ar1.SelectChipVersion("IWR6843") [17:57:15] [RadarAPI]: Status: Passed [17:57:15] [RadarAPI]: ar1.SelectChipVersion("IWR6843") [17:57:15] [RadarAPI]: Status: Passed [17:57:15] Device Status : IWR6843/QM/SOP:2/ES:2 [17:57:15] [RadarAPI]: ar1.RfEnable() [17:57:15] BSS power up done async event received! [17:57:15] [RadarAPI]: Status: Passed [17:57:16] [RadarAPI]: ar1.GetMSSFwVersion() [17:57:16] [RadarAPI]: MSSFwVersion:(02.00.00.03 (27/08/19)) [17:57:16] [RadarAPI]: ar1.GetBSSFwVersion() [17:57:16] [RadarAPI]: BSSFwVersion:(06.02.01.05 (09/03/20)) [17:57:22] [RadarAPI]: ar1.ChanNAdcConfig(1, 1, 0, 1, 1, 1, 1, 2, 1, 0) [17:57:22] [RadarAPI]: Status: Passed [17:57:24] [RadarAPI]: ar1.LPModConfig(0, 0) [17:57:24] [RadarAPI]: Status: Passed [17:57:25] [RadarAPI]: ar1.RfInit() [17:57:25] RF Init async event received! [17:57:25] [RadarAPI]: Time stamp, Temperture: 9606,50; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 1, 1; RxIQMM Status, Update: 1, 1; [17:57:25] [RadarAPI]: Status: Passed [17:57:30] [RadarAPI]: ar1.DataPathConfig(513, 1216644097, 0) [17:57:30] [RadarAPI]: Status: Passed [17:57:33] [RadarAPI]: ar1.LvdsClkConfig(1, 1) [17:57:33] [RadarAPI]: Status: Passed [17:57:34] [RadarAPI]: ar1.LVDSLaneConfig(0, 1, 1, 0, 0, 1, 0, 0) [17:57:34] [RadarAPI]: Status: Passed [17:57:40] [RadarAPI]: ar1.ProfileConfig(0, 60, 100, 6, 60, 0, 0, 0, 0, 0, 0, 29.982, 0, 256, 10000, 0, 131072, 30) [17:57:40] [RadarAPI]: Status: Passed [17:57:42] [RadarAPI]: ar1.ChirpConfig(0, 0, 0, 0, 0, 0, 0, 1, 0, 0) [17:57:42] [RadarAPI]: Status: Passed [17:57:43] Test Source Already Disabled...!!! [17:57:43] [RadarAPI]: ar1.DisableTestSource(0) [17:57:43] [RadarAPI]: Status: Passed [17:57:43] [RadarAPI]: ar1.FrameConfig(0, 0, 8, 128, 40, 0, 0, 1) [17:57:43] [RadarAPI]: Status: Passed [17:57:58] [RadarAPI]: ar1.GetCaptureCardDllVersion() [17:57:58] [RadarAPI]: Sending dll_version command to DCA1000 [17:57:58] [RadarAPI]: [17:57:58] DLL Version : 1.0 [17:57:58] [RadarAPI]: ar1.SelectCaptureDevice("DCA1000") [17:57:58] [RadarAPI]: Status: Passed [17:58:04] [RadarAPI]: ar1.CaptureCardConfig_EthInit("192.168.33.30", "192.168.33.180", "12:34:56:78:90:12", 4096, 4098) [17:58:04] [RadarAPI]: ar1.CaptureCardConfig_Mode(1, 2, 1, 2, 3, 30) [17:58:04] [RadarAPI]: ar1.CaptureCardConfig_PacketDelay(25) [17:58:04] [RadarAPI]: Sending fpga command to DCA1000 [17:58:14] [RadarAPI]: [17:58:14] FPGA Configuration : [17:58:14] Timeout Error! System disconnected [17:58:14] [RadarAPI]: Sending record command to DCA1000 [17:58:25] [RadarAPI]: [17:58:25] Configure Record : [17:58:25] Timeout Error! System disconnected [17:58:25] [RadarAPI]: ar1.GetCaptureCardFPGAVersion() [17:58:25] [RadarAPI]: Sending fpga_version command to DCA1000 [17:58:36] [RadarAPI]: [17:58:36] [17:58:36] Unable to read FPGA Version. [error -5] [17:58:36]
Dear support team,
I am trying to capture LVDS data with DCA1000 by following training video ;
DCA1000 Training Video | TI.com Video
But FPGA version is not detected and "timeout error" is reported. Please kindly check the log and let me know the possible root cause.
Taka
