LDCCOILEVM: PCB Fabrication of LDCCOILEVM board
Part Number: LDCCOILEVM
Hi Team,
My customer would like to know following PCB Fabrication information of LDCCOILEVM board.
Could you please tell me the following about the PCB Fabrication information of this board?
1. board thickness
2. surface layer copper foil + copper plating thickness(Finished Copper information)
3. prepreg material information
4. surface layer material information
5. minimum Via hole diameter(Min Hole Size)
6. minimum land diameter(Min Track/Spacing)
7. Minimum distance between land and wiring pattern(Min Track/Spacing)
8. minimum distance between Via hole and wiring pattern(Min Track/Spacing)
9. other special specifications (with or without impedance control, etc.)
Takashi Onawa
