IWR1843BOOST+DCA1000EVM: Runtime Binding on Null Reference
GM: Constructor
GM: Mon Mar 29 17:03:26 2021
RSTD.Transmit("/Settings")
[17:03:26]
[17:03:26] ### Running Startup script: "C:\ti\mmwave_studio_02_01_01_00\mmWaveStudio\Scripts\Startup.lua" ###
[17:03:26] RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
[17:03:26] RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
[17:03:26] Scripter ignored: Attempt to UnBuild() again or before Build.
[17:03:26] RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "C:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\Clients\\\\LabClient.dll")
[17:03:26] RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
[17:03:26] RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
[17:03:26] RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
[17:03:26] RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
[17:03:26] RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
[17:03:26] RSTD.SetVar ("/Settings/AL Client/AL Dll" , "C:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\RunTime\\SAL.dll")
[17:03:26] RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
[17:03:26] RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
[17:03:26] RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
[17:03:26] RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
[17:03:26] RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
[17:03:26] RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
[17:03:26] RSTD.Transmit("/")
[17:03:26] RSTD.SaveSettings(): Settings saved to "C:\Users\jihyunl2\AppData\Roaming\RSTD\config.xml"
[17:03:26] RSTD.Build()
[17:03:27] RSTD.SaveSettings(): Settings saved to "C:\Users\jihyunl2\AppData\Roaming\RSTD\config.xml"
[17:03:27] RSTD.Transmit("/")
[17:03:27] RSTD.AL_Build()
[17:03:27] RSTD.AL_LoadXml()
[17:03:27] RSTD.AL_Init()
[17:03:27] RSTD.Clients_Build()
[17:03:27] GM: Init
[17:03:27] GM: Loaded 'C:\ti\mmwave_studio_02_01_01_00\mmWaveStudio\Clients\\LabClient.dll'
[17:03:27] GM: 1 Guest (s) init
[17:03:27] GM: 1 Module(s) init
[17:03:27] GM: 2 Tab (s) init
[17:03:27] RSTD.Client_LoadXml()
[17:03:27] [RadarAPI]: ar1.selectRadarMode(0)
[17:03:27] [RadarAPI]: Status: Passed
[17:03:27] Matlab Runtime Engine is installed
[17:03:27] [RadarAPI]: Starting Matlab Engine..
[17:03:34] [RadarAPI]: Matlab Engine Started!
[17:03:36] [RadarAPI]: ar1.selectCascadeMode(0)
[17:03:36] [RadarAPI]: Status: Passed
[17:03:36] [RadarAPI]: ar1.LoadSettings('C:\Users\jihyunl2\AppData\Roaming\RSTD\ar1gui.ini')
[17:03:37] TESTING = false
[17:03:37] RstdNet: Port 2777: Listening..
[17:03:37]
[17:03:37] ***Script completed successfully.***
[17:03:47] [RadarAPI]: Opening Gpio Control Port()
[17:03:47] [RadarAPI]: Status: Passed
[17:03:48] [RadarAPI]: Opening Board Control Port()
[17:03:48] [RadarAPI]: Status: Passed
[17:03:49] [RadarAPI]: ar1.FullReset()
[17:03:49] [RadarAPI]: Status: Passed
[17:03:49] [RadarAPI]: Closing Board Control Port()
[17:03:50] [RadarAPI]: Closing Gpio Control Port()
[17:03:50] [RadarAPI]: Status: Passed
[17:03:50] [RadarAPI]: ar1.SOPControl(2)
[17:04:03] [RadarAPI]: ar1.Connect(3,921600,1000)
[17:04:05] [RadarAPI]: Warning: Connected with baudrate 115200
[17:04:07] [RadarAPI]: Warning: Disconnected existing BaudRate
[17:04:07] [RadarAPI]: Warning: Trying to connect with baudrate 921600
[17:04:08] [RadarAPI]: ar1.Calling_IsConnected()
[17:04:09] [RadarAPI]: ar1.SelectChipVersion("AR1642")
[17:04:10] [RadarAPI]: Status: Passed
[17:04:10] [RadarAPI]: ar1.SelectChipVersion("AR1642")
[17:04:10] [RadarAPI]: ar1.deviceVariantSelection("XWR1843")
[17:04:10] [RadarAPI]: ar1.frequencyBandSelection("77G")
[17:04:10] [RadarAPI]: ar1.SelectChipVersion("XWR1843")
[17:04:10] Device Status : XWR1843/QM/SOP:2/ES:2
[17:04:10] [RadarAPI]: ar1.SaveSettings('C:\Users\jihyunl2\AppData\Roaming\RSTD\ar1gui.ini')
[17:05:02] [RadarAPI]: ar1.ReadRegister(0xffffe214, 0, 31)
[17:05:03] [RadarAPI]: ar1.ReadRegister(0xffffe210, 0, 31)
[17:05:03] [RadarAPI]: ar1.ReadRegister(0xffffe218, 0, 31)
[17:05:03] [RadarAPI]: ar1.DownloadBSSFw("C:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\Scripts\\..\\..\\rf_eval_firmware\\radarss\\xwr18xx_radarss.bin")
[17:05:03] [RadarAPI]: Downloading BSS Patch RPRC Binary..
[17:05:05] [RadarAPI]: ar1.GetBSSFwVersion()
[17:05:05] [RadarAPI]: BSSFwVersion:(02.00.00.01 (05/10/17))
[17:05:06] [RadarAPI]: ar1.GetBSSPatchFwVersion()
[17:05:06] [RadarAPI]: BSSPatchFwVersion:(01.02.05.02 (30/04/19))
[17:05:06] BSS FW Download Success
[17:05:06] [RadarAPI]: ar1.DownloadMSSFw("C:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\Scripts\\..\\..\\rf_eval_firmware\\masterss\\xwr18xx_masterss.bin")
[17:05:06] [RadarAPI]: Downloading MSS RPRC Binary..
[17:05:08] [RadarAPI]: ar1.GetMSSFwVersion()
[17:05:08] [RadarAPI]: MSSFwVersion:(01.02.05.02 (16/07/19))
[17:05:08] MSS FW Download Success
[17:05:09] [RadarAPI]: ar1.PowerOn(0, 1000, 0, 0)
[17:05:09] [RadarAPI]: Status: Passed
[17:05:09] MSS power up done async event received!
[17:05:09] Power On Success
[17:05:10] [RadarAPI]: ar1.SelectChipVersion("AR1642")
[17:05:10] [RadarAPI]: Status: Passed
[17:05:10] [RadarAPI]: ar1.SelectChipVersion("XWR1843")
[17:05:10] Device Status : XWR1843/QM/SOP:2/ES:2
[17:05:10] [RadarAPI]: ar1.RfEnable()
[17:05:10] BSS power up done async event received!
[17:05:11] [RadarAPI]: ar1.GetMSSFwVersion()
[17:05:11] [RadarAPI]: MSSFwVersion:(01.02.05.02 (16/07/19))
[17:05:11] [RadarAPI]: ar1.GetBSSFwVersion()
[17:05:11] [RadarAPI]: BSSFwVersion:(02.00.00.01 (05/10/17))
[17:05:12] [RadarAPI]: ar1.GetBSSPatchFwVersion()
[17:05:12] [RadarAPI]: BSSPatchFwVersion:(01.02.05.02 (30/04/19))
[17:05:12] RF Enable Success
[17:05:12] [RadarAPI]: ar1.ChanNAdcConfig(1, 1, 0, 1, 1, 1, 1, 2, 1, 0)
[17:05:12] [RadarAPI]: Status: Passed
[17:05:12] ChanNAdcConfig Success
[17:05:12] [RadarAPI]: ar1.LPModConfig(0, 0)
[17:05:12] Regualar mode Cfg Success
[17:05:12] [RadarAPI]: ar1.RfInit()
[17:05:13] RF Init async event received!
[17:05:13] [RadarAPI]: Time stamp, Temperture: 2328,41; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 1, 1; RxIQMM Status, Update: 1, 1;
[17:05:13] [RadarAPI]: Status: Passed
[17:05:13] RfInit Success
[17:05:14] [RadarAPI]: ar1.DataPathConfig(1, 1, 0)
[17:05:14] [RadarAPI]: Status: Passed
[17:05:14] DataPathConfig Success
[17:05:14] [RadarAPI]: ar1.LvdsClkConfig(1, 1)
[17:05:14] LvdsClkConfig Success
[17:05:14] [RadarAPI]: ar1.LVDSLaneConfig(0, 1, 1, 0, 0, 1, 0, 0)
[17:05:14] LVDSLaneConfig Success
[17:05:14] [RadarAPI]: ar1.SetTestSource(4, 3, 0, 0, 0, 0, -327, 0, -327, 327, 327, 327, -2.5, 327, 327, 0, 0, 0, 0, -327, 0, -327, 327, 327, 327, -95, 0, 0, 0.5, 0, 1, 0, 1.5, 0, 0, 0, 0, 0, 0, 0)
[17:05:14] Test Source Configuration Success
[17:05:14] [RadarAPI]: ar1.ProfileConfig(0, 77, 100, 6, 60, 0, 0, 0, 0, 0, 0, 29.982, 0, 256, 5000, 0, 0, 30)
[17:05:14] ProfileConfig Success
[17:05:14] [RadarAPI]: ar1.ChirpConfig(0, 0, 0, 0, 0, 0, 0, 1, 1, 0)
[17:05:14] ChirpConfig Success
[17:05:14] [RadarAPI]: ar1.EnableTestSource(1)
[17:05:14] Enabling Test Source Success
[17:05:14] Test Source Already Enabled...!!!
[17:05:14] [RadarAPI]: ar1.FrameConfig(0, 0, 8, 128, 40, 0, 0, 1)
[17:05:15] [RadarAPI]: Status: Passed
[17:05:15] FrameConfig Success
[17:05:15] [RadarAPI]: ar1.SelectCaptureDevice("DCA1000")
[17:05:15] SelectCaptureDevice Success
[17:05:16] [RadarAPI]: ar1.CaptureCardConfig_EthInit("192.168.33.30", "192.168.33.180", "c:22:38:4e:5a:c", 4096, 4098)
[17:05:16]
[17:05:16] &&&&&&&&&&&&&&&&&&&&
[17:05:16] ***Script FAILED!***
[17:05:16] Exception message is:
[17:05:16] Cannot perform runtime binding on a null reference
This is the log of when I run DataCaptureDemoxWR.lua
Below is my current setup.
I don't think my host machine can identify the DCA1000 board. Are there any possible reasons behind this?
