Other Parts Discussed in Thread: CODECOMPOSER
Hi Team,
Can you please check and advise with following request?
We are working on TI AWR6843 chipset and using slightly different antennas but very similar to AWR6843ISK-ODS EVM. We want to test the performance of antennas in our PCB. We observed that you have shared the antenna performances for each antenna pair in "60 GHz mmWave Sensor EVMs" document. What is the required test set up to obtain this results? We have thought that you had used a constant reflector in front of the EVM and you have collected the captured data from ADC for each angle of rotation. Is this correct? And if yes, could you please share the source code for this test?
Thanks in advance
Best Regards
Furkan Sefiloglu
