Part Number: LMT70
Hi team,
My customer is using the LMT70 in their design. They are seeing a variable offset that appears on the LMT70YFQT output whenever we power cycle it. The offset is random and changes even when the unit is cycled quickly. The offset seems to persist and the output does not settle to the original value. THey feed the device from a 3.3 volt power supply which is derived from a switch mode supply, but with some filtering.
Is the LMT70YFQT susceptible to power supply noise or value?
Is the output susceptible to noise pick up or is it fairly low impedance?
Should the output have any filter capacitance on it?
Thank you in advance for your support!
Errol
