AWR1642BOOST: What's the relation between Chirp, Frame and Frame Header ?
Part Number: AWR1642BOOST
I am little confused about understanding chirp, frame relation and Frame Header, MATLAB reads "frameNumber" inside getHeader() function, Is each Frames contains the object data or what?
    The header is defined by the application. It is the container for the detected object data (detected number of objects, x,y, velocity...)
    This basically contains all the information the sensor wants to sends to the host.
    The SRR demo uses the header format defined in the early version (version 1.x) of the mmWave SDK.
    This is just an example, any application developer can define it's own header format
    thank you
    Cesar
