MMWCAS-RF-EVM: longer capture time and lower sample rate on mmW cascade board
Part Number: MMWCAS-RF-EVM
Greetings.
For unknow reason I cannot mark my previous label "resolved" post   [longer capture time and lower sample rate on mmW cascade board]  back to pending. I simply repost here.
i have not figure out the solution for:  longer capture time  when running run `Cascade_Configure_MIMO.lua` and `Cascade_Caputure.lua`. Follow answer, I increase the  nframes_master  nframes_slave. I see the data size increase but not for time duration
I plan to collect to 60 second, ignore the confusing output time gap, I feel like the time gap I press the GUI button "Run!" to WinSCP window is definitely smaller than 60 seconds.
I even write two line my own script in the `Cascade_Capture.lua` to record current time. Both right after  line 95 ` WriteToLog("Starting Frame Trigger sequence ... \n","blue")   `  and  line 133  `WriteToLog("Capture sequence completed ... \n",'"blue")`, I write `print(os.date("%H:%M:%S"))`, and in this way I record time capture begin and ends, still it looks it is still around 2 seconds.
also I attached the .lua script below
while for Cascade_Config_MIMO.lua it is
Does the mmW board or anyone really did long-time data collection?
Best
Jet
