Other Parts Discussed in Thread: TMP468,
Team,
If I use (3) TMP112 parts and (1) TMP468 part, can I use the same I2C bus? I would assume putting the 468 ADD pin to ground.
Hi Michael,
Yes you can. You would simply need to connect the address pins on your 3 TMP112s such that the address did not conflict with the address option you chose for the TMP468.
TMP112 | TMP468 |
So if you connected the TMP468 address pin to ground, you would want to connect the A0 Pins of your TMP112s to V+, SDA, or SCL, ensuring all three were connected differently.
Brandon Fisher
