I do not how to adjust profile parameters.
Use Visualizer? or Estimator?
Is there a video tutorial for profile parameters adjust.
I think we can not get the ideal parameter through Visualizer.
Thanks.
Thanks.
What demo are you using? Most of these CFG parameters are described in the MMwave SDK User's Guide, in the section titled "Configuration (.cfg) File Format". There may be some additional parameters depending on what demo you are leveraging, but the majority will be found in the user's guide.
Alec
I may need you to elaborate a bit on what you mean. In order to adjust these CFG, grab the CFG file from whatever demo/project that you are using, and open it in your text editor of choice and make the modifications based on what you believe to be beneficial for your application.
Alec
I would recommend that you utilize the visualizer for whichever demo you are trying to run and make incremental adjustments to your .cfg parameters in order to best suit your specific environment. Make an adjustment that seems logical based on your setup, test it with the visualizer to determine whether you see an improvement or not, and repeat. Let me know if there are further questions.
Alec
