Other Parts Discussed in Thread: TDC7200,
Hello there,
I would like to use LDC1101 in DRDY RP+L mode with external time measurement such as TDC7200 described in SNOA941A which should deliver that best achievable resolution possible. Latency between sensing a change in position (frequency of oscillation) and reporting it is crucial for my application.
As I read the LDC1101 reference manual (SNOSD01D) I found that Response_Time can be selected for multiple values based on required conversion time and resolution.
In 7.5 Electrical Characteristics of SNOSD01D It says that minimum response time (RP+L mode) is 192/Fsensor but maximum sample rate is (3xFsensor)/ResponseTime, where minimum Response Time is 192.
What does it mean that for response time it is 192/Fsensor and for sample rate (conversion time) it is 192/3x Fsensor? What is difference?
What is then actual latency between measured movement change and DRDY assertion)?
Thank you,
Michael
