Other Parts Discussed in Thread: LMP91300
Hello TI team,
I need to communicate / program the device LMP91300 with LabWiev.
I read in the forum that you have VIs that you can use to implement the code.
How can I have the VI ?.
Thank you
Hello TI team,
Thank you
Hi Vincenzo,
I will try to find the Labview VI and will get back to you tomorrow. Can you please link the thread which you referred to in your question?
Hi Ben,
my name is Stefano Anceschi, and I'm a Giudicissi's collegue.
I'm trying to use labview routines you passed us, but I've some kind of difficulties, may you help me?
The Demo Labview program cannot detect any board ( error - 1)
I attached the log file generated by labview.
What I'm doing wrong?
16/06/20:13:16:24.0504:SCRIPT_EP:__log.txt not found: Logs not enabled 16/06/20:13:16:24.0504:SCRIPT_EP:CINT init params:cint -IC:\hardware\scripts\include -IC:\hardware\scripts -qlevel1 -Z0 16/06/20:13:16:24.0505:SCRIPT_EP:!!! 0 object(s) deleted by Reference Count Control !!! 16/06/20:13:16:24.0517:SCRIPT_EP:Error: cannot open file "script_api.h" (0) 16/06/20:13:16:24.0517:SCRIPT_EP:Error: cannot open file "gen_access.h" (0) 16/06/20:13:16:24.0518:SCRIPT_EP:Error: cannot open file "gen_access.cpp" (0) 16/06/20:13:16:24.0518:SCRIPT_EP:Error: cannot open file "utils.h" (0) 16/06/20:13:16:24.0518:SCRIPT_EP:Error: cannot open file "utils.cpp" (0) 16/06/20:13:16:24.0519:SCRIPT_EP:Error: cannot open file "spi_auto_mode.h" (0) 16/06/20:13:16:24.0519:SCRIPT_EP:Error: cannot open file "spi_auto_mode.cpp" (0) 16/06/20:13:16:24.0519:BOARD_STATE:USB config: WINUSB_SUPPORT 16/06/20:13:16:24.0519:UTILS:Simulator settings not found. Continuing. 16/06/20:13:16:24.0519:UTILS:Looking for image map file:C:\hardware\scripts\image_map.xml 16/06/20:13:16:24.0519:UTILS:Image map file not found:C:\hardware\scripts\image_map.xml 16/06/20:13:16:24.0520:CMD:return:DLL_COMMAND_RET_OK 16/06/20:13:16:24.0520:CMD_API:Ack received. Releasing API. 16/06/20:13:16:24.0520:CMD_API:==== Command complete ==== 16/06/20:13:16:24.0520:CMD_API:==== Starting new command ==== 16/06/20:13:16:24.0520:CMD_API:Waiting for API 16/06/20:13:16:24.0520:CMD_API:Posting command 16/06/20:13:16:24.0526:CMD:Processing ... 16/06/20:13:16:24.0526:CMD:DLL_Board_Enum 16/06/20:13:16:24.0526:BOARD_STATE:Skipping error board 16/06/20:13:16:24.0526:BOARD_STATE:Board count:0 16/06/20:13:16:24.0526:GEN:Dll version:2.0.0.5 16/06/20:13:16:24.0526:CMD:return:DLL_COMMAND_RET_OK 16/06/20:13:16:24.0526:CMD_API:Ack received. Releasing API. 16/06/20:13:16:24.0526:CMD_API:==== Command complete ==== 16/06/20:13:16:29.0753:CMD_API:==== Starting new command ==== 16/06/20:13:16:29.0753:CMD_API:Waiting for API 16/06/20:13:16:29.0753:CMD_API:Posting command 16/06/20:13:16:29.0759:CMD:Processing ... 16/06/20:13:16:29.0759:CMD:Dll_Board_Close:0 16/06/20:13:16:29.0759:BOARD_STATE:board_close():0 16/06/20:13:16:29.0759:BOARD_STATE:Board was not allocated 16/06/20:13:16:29.0759:CMD:return:DLL_COMMAND_RET_OK 16/06/20:13:16:29.0759:CMD_API:Ack received. Releasing API. 16/06/20:13:16:29.0759:CMD_API:==== Command complete ====
