Part Number: IWR1642
Other Parts Discussed in Thread: MATHLIB, SYSBIOS
**** Build of configuration Debug for project mmw_dss ****
"D:\\TI\\ccsv7\\utils\\bin\\gmake" -k -j 8 all -O
rm -f D:/workspace_v7/mmw_dss/xwr16xx_mmw_dss.bin
makefile:187: recipe for target 'pre-build' failed
process_begin: CreateProcess(NULL, rm -f D:/workspace_v7/mmw_dss/xwr16xx_mmw_dss.bin, ...) failed.
make (e=2): The system cannot find the file specified.
gmake[1]: [pre-build] Error 2 (ignored)
'Building target: xwr16xx_mmw_dss.xe674'
'Invoking: C6000 Linker'
"D:/TI/ccsv7/tools/compiler/ti-cgt-c6000_8.1.3/bin/cl6x" -mv6740 --abi=eabi -O3 -g --gcc --define=SOC_XWR16XX --define=SUBSYS_DSS --define=DOWNLOAD_FROM_CCS --define=DebugP_ASSERT_ENABLED --define=_LITTLE_ENDIAN=1 --diag_wrap=off --display_error_number --diag_warning=225 --gen_func_subsections=on --obj_extension=.oe674 -z -m"xwr16xx_mmw_dss.map" --stack_size=0x800 --heap_size=0x800 -i"C:/ti/mmwave_sdk_01_00_00_05/packages/ti/control/mmwave/lib" -i"C:/ti/mmwave_sdk_01_00_00_05/packages/ti/control/mmwavelink/lib" -i"C:/ti/mmwave_sdk_01_00_00_05/packages/ti/drivers/crc/lib" -i"C:/ti/mmwave_sdk_01_00_00_05/packages/ti/drivers/mailbox/lib" -i"C:/ti/mmwave_sdk_01_00_00_05/packages/ti/drivers/osal/lib" -i"C:/ti/mmwave_sdk_01_00_00_05/packages/ti/drivers/soc/lib" -i"C:/ti/mmwave_sdk_01_00_00_05/packages/ti/drivers/uart/lib" -i"C:/ti/mmwave_sdk_01_00_00_05/packages/ti/drivers/edma/lib" -i"C:/ti/mmwave_sdk_01_00_00_05/packages/ti/drivers/adcbuf/lib" -i"C:/ti/mmwave_sdk_01_00_00_05/packages/ti/alg/mmwavelib/lib" -i"C:/ti/dsplib_c64Px_3_4_0_0/packages/ti/dsplib/lib" -i"C:/ti/mathlib_c674x_3_1_2_1/packages/ti/mathlib/lib" -i"D:/TI/ccsv7/tools/compiler/ti-cgt-c6000_8.1.3/lib" -i"D:/TI/ccsv7/tools/compiler/ti-cgt-c6000_8.1.3/include" --reread_libs --disable_auto_rts --define=_LITTLE_ENDIAN --display_error_number --diag_wrap=off --warn_sections --diag_warning=225 --xml_link_info="xwr16xx_mmw_dss_linkInfo.xml" --ram_model --unused_section_elimination=on -o "xwr16xx_mmw_dss.xe674" "./dss_config_edma_util.oe674" "./dss_data_path.oe674" "./dss_main.oe674" "../c674x_linker.cmd" "../dss_mmw_linker.cmd" -l"configPkg/linker.cmd" -llibosal_xwr16xx.ae674 -llibsoc_xwr16xx.ae674 -llibcrc_xwr16xx.ae674 -llibuart_xwr16xx.ae674 -llibmailbox_xwr16xx.ae674 -llibmmwavelink_xwr16xx.ae674 -llibmmwave_xwr16xx.ae674 -lmathlib.ae674 -ldsplib.ae64P -llibedma_xwr16xx.ae674 -llibadcbuf_xwr16xx.ae674 -llibmmwavealg_xwr16xx.ae674 -lrts6740_elf.lib -llibc.a -llibc.a
<Linking>
undefined first referenced
symbol in file
gen_twiddle_fft16x16 ./dss_data_path.oe674
gen_twiddle_fft32x32 ./dss_data_path.oe674
error #10234-D: unresolved symbols remain
error #10010: errors encountered during linking; "xwr16xx_mmw_dss.xe674" not built
>> Compilation failure
makefile:163: recipe for target 'xwr16xx_mmw_dss.xe674' failed
gmake[2]: *** [xwr16xx_mmw_dss.xe674] Error 1
makefile:159: recipe for target 'main-build' failed
gmake[1]: *** [main-build] Error 2
makefile:154: recipe for target 'all' failed
gmake: *** [all] Error 2
**** Build Finished ****
