Other Parts Discussed in Thread: CCSTUDIO
Hi Experts,
I tried to modify the MMWave Demo to bypass the CLI configuration and use a fixed configuartion.
I followed the “How to bypass CLI” steps from the SDK
... /ti/mmwave_sdk_03_02_00_04/packages/ti/demo/xwr64xx/mmw/docs/doxygen/html/index.html
I haven't been able to get it to work yet because the given description of the different steps are very rudimental and difficult to implement.
Do you have a more detailed explanation or maybe an example code?
For example, the guidance says "call MmwDemo_openSensor" and then "call MmeDemo_startSensor". Is this correct? In my opinion the config_Sensor has to be called in between.
By the way I have some debug issues which makes it even more difficult to analyze the code. I turned the optimization level to zero but the debugger still does not halt at breakpoints.
Thaks,
Lukas
