Part Number: AFE7950EVM
Other Parts Discussed in Thread: TSW14J58EVM,
I am using the AFE7950EVM together with the TSW14J58EVM.
When I enable multiple RX channels for reception and save the captured data to a CSV file, I always obtain only a single complex data column (I,Q), even though multiple receivers are selected.
Could you please provide the correct procedure and required instructions to properly capture and export data from multiple RX channels simultaneously into the CSV file?
For example, I would like to acquire and save data from several receivers in parallel (e.g., RXA, RXB, RXC, RXD), with each channel correctly exported as separate I/Q columns.
Could you please indicate:
- the required Latte configuration,
- the correct capture settings,
- any necessary HSDC Pro settings (if applicable),
- and the expected CSV file structure for multi-channel acquisition?
Thank you very much for your support.
