Other Parts Discussed in Thread: TMUX1219, TMUX1574, TMUX1136, TMUX1575
engineer is seeking a 1ohm SPDT switch that can operate on analog supply, similar to TS5A3160, but searching for the same type of switch, but can take lower input voltage around 1.59V.
After reviewing our 1ohm on resistance switches, it appears they all have a min analog operating supply of 1.65V, so I suspect this is a process limitation.
I did find the TMUX1219, which has a wider analog supply range, but it has higher on resistance of 3 ohms which is not acceptable.
Does the product team have other product suggestions? Am I overlooking an option?
Carl Wolfe
