Hello TI TEAM
Can you please share the reference schematic of LMH6586EVAL?
Please see our EVM user's guide linked below for information regarding the schematic and other insights about this EVM/device.
Thanks!
Bryan
Hello Bryan
Thanks for sharing the file .
The schematic page of this user guide is getting blurred with zooming and not able to read refdes or other information of sch properly .
Can you please provide that in good and readable view ?
Hello TI Team
one more query regarding terminated load of 150 ohm , please correct us if our understanding is wrong
1) Using only 75 ohm trace and connect with Load, this will not work ? as current requirement of load will be increase as compare to case where 150 ohm terminated load is used.
I tried to get a better resolution view of the schematic and have it attached below. Should be a bit clearer.
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/388/LMH6586-Schematic.emf
In regards to the loading, yes, the device is specified to support a 150Ohm load. So any loads less than this could cause an issue with the current capability of the part itself, hence it is best to stay within this specification.
Thanks!
Bryan
