Hi there
Is there power on timing for this IC?
For example, EN# pin should pull low before or after IN pin?
Mike Hsu
Hi there
Mike Hsu
Hi Mike,
For the logic pins, there is no timing requirement for which one should be on first. Just note that the /EN pin will disable all channels at once and the IN pin will select which channel is active, so need to understand how you would like to control the mux for your system needs (/EN takes priority, so it will not matter what state the IN pin is in when the /EN pin is high).
Thanks!
Bryan
