Hi experts,
My customer would like to replace from CD74HCT4067QM96Q1 to CD74HCT4067M.
Are there any differences like the package outline and electrical characteristics between them without Q100 quality?
Shunsuke Yamamoto
Hi experts,
Shunsuke Yamamoto
Hi Shunsuke,
The package outline is the same between the devices but there are some minor differences in specs. The commercial part has a more limited temperature range: -40C to 125C vs -55C to 125C for the Q1 device. The expanded temperature range for the Q1 device means that some of the full range datasheet values might differ between them. In general, the Q1 version is automotive qualified (AEC-Q100), meaning it goes under extra testing to verify that it will meet the automotive requirements.
Tyler
Hi Tyler-san,
Thank you for your prompt reply.
When I saw the datesheet of CD74HCT4067QM96Q1 and CD74HCT4067M, the operating temperature range of CD74HCT4067QM96Q1 is more limited than the operating temperature range of CD74HCT4067M.
Shunsuke Yamamoto
Hi Shunsuke-san,
You are correct, I mixed them up in my first response. The Q1 version has the more limited temp range. If you have any more questions, please reach out!.
Tyler
Hi Tyler-san,
Thank you for your reply.
What is the cause of the limited temp range of Q1 version?
Shunsuke Yamamoto
HI Shunsuke-san,
The automotive version is specified in this way since it was tested in accordance with AEC-Q100 guidelines which state a temperature range of -40C to 125C.
Tyler
Hi Tyler-san,
I understood why the automotive version has more limited operating temperature range.
Why is the operating temperature range of the commercial version of CD74HCT4067 wider than the automotive version of CD74HCT4067?
For example, Some of the automotive version and the commercial verison have same operating temperature range.
Shunsuke Yamamoto
Hi Shunsuke-San,
We are currently on holiday and will respond by 9/6.
Thanks!
Bryan
Hi Shunsuke-san,
This device was developed by a company TI acquired (Harris Semiconductor) so I do not have good insight into why they qualified the commercial version down to -55C. It does appear that all the former Harris devices are -55C rated, this was likely the normal range used for qualification. The automotive version came later and went through the qual process with the AEC-Q100 grade 1 specified temperature range of -40C to 125C. You are correct that our more recently released devices have the same temperature rating between commercial and automotive devices.
Tyler
