TMUX1575: eval board layout file in Cadence .brd file
Part Number: TMUX1575
Can not open the layout file that you shared on the forum.  Please share the eval board design file, prefer Cadence .brd file,
  • Hey Steve,
    Can you not open or download the zip file at all? Or is it an issue of the files being gerber files and you can't open it in your current PCB layout designer (ie Eagle)?
    We do not have brd files since my understanding is that this is a Eagle specific file type and we did not use this to create the layout. Reading up on this though, I believe there should be a way to import the altium design file to Eagle. You may be able to do something along the lines of File -> Import -> Gerber.
    In case this doesn't work, was there something in particular that you were interested in that I can look into for you? I can help provide any information since I have the correct software.
    I've also reattached the gerber/NCdrill files from the post you referenced, in case the issue was that you simply couln't download the .zip itself.
    4431.16YCJTM1575EVM_Gerber_NCdrills_IPC.zip
    Rami
