Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
SN74CBTLV3251: more leakage on B8
Part Number: SN74CBTLV3251
SN74CBTLV3251RGYR, when powered off, should have 20uA leakage into it. It’s complying with that,
but we are seeing much higher leakage on B8 than any of the other inputs. Is there anything in the chip
architecture that can explain this? Leakage is higher on B8 than other pins, does that make sense?
Again, it’s not broken or wrong, we just happen to have a nosy customer who wants an explanation of
some weirdness we are seeing and we narrowed it down to this observation.
Adam
  • Hey Adam,
    There isn't anything in the architecture that would explain why only B8 would have a higher leakage. The channels should be pretty symmetrical. Is this exact behavior seen across multiple devices and is the load and inputs otherwise the exact same for all 8 I/O's?
    Rami
