Other Parts Discussed in Thread: SN74LVC1G18, , TS5A23157-Q1
Does SN74CBT3257 or SN74LVC1G18 suitable for I2S 1:2 switch application?
Or any other better suggestion?
Thanks!
Jeff
Thanks!
Jeff
In general, routing one output to several CMOS inputs is no problem. (If you suspect that the load becomes too high, you can add buffers.)
You need some kind of switch or demultiplexer only if you want to disable one of them.
Hi Jeff,
I suggest using the TS5A23157-Q1. It is a 1;2 device and has 2 channels which means it can output two signals at the same time.
Here is an FAQ that talks about I2S in more detail.
Please let me know if you need any further assistance!
Thanks and Regards,
Kameron
