Part Number: TMUX136
On TMUX136, can I connect the OE pin directly to ground? Or should I place a resistor between the pin and ground?
Thank you!
Zach Kimble
Thank you!
Zach Kimble
Hey Zach,
Yes, the enable pin can be tied directly to ground. Of course, you'll lose functionality of it and won't be able to isolate the device channels but if you don't care about that functionality, then grounding it directly is fine.
Thanks!
Rami
Thank you Rami! I plan to always keep the device enabled when there is power on the VCC pin so not being able to control EN is not an issue for me.
