Other Parts Discussed in Thread: TCA9548A, TCA9546A, , SN74LV4051A
Hi team,
do we have recommendation for below requests?
1. 4ch 2.3-5.5V I2C/SMBUS MUX
2. 8ch 2.3-5.5V I2C/SMBUS MUX
Hi team,
Usually, you'd want to use a switch that can itself be controlled through I²C. See TCA9546A or TCA9548A; these devices also support level shifting.
If you want to control the switch with separate GPIO signals, you can use any analog switch that supports your supply voltage and has a low-enough Ron. The SN74LV4052A or 2x SN74LV4051A would work fine.
