Part Number: TS3L500AE
Other Parts Discussed in Thread: TS3L500
I'm using a TS3L500AE as a multiplexer for Ethernet on a custom PCB. The PCB has one input RJ45 socket and two output sockets. Continuity tests on the pins show everything is working, and I'm able to switch outputs successfully. However, when I plug in cables, the connection doesn't work.
For example:
- Router -> Cable -> Adapter -> Cable -> Laptop: Works
- Router -> Cable -> PCB with TS3L500 -> Cable -> Laptop: Doesn't work
Could anyone help me figure out what's wrong? Do I need to amplify the signal? What tests can I run to ensure my design isn't fundamentally flawed?
