TS3USB30: -3DB bandwidth parameter test
Part Number: TS3USB30
Hi Team,
TS3USB30E -3DB bandwidth
According to the measurement method provided on specifications, it is to continuously increase the signal frequency at the input end until 900Mhz to observe whether the output amplitude becomes 0.707;
However, due to the limited equipment of our test equipment, the signal generator we use can only increase the signal frequency up to 350Mhz, which makes this parameter difficult to measure; I also know whether the spectrum analyzer can be used to observe this parameter, but according to your company's requirements, I need to add a DC bias of 350mv at the same time, and the spectrum analyzer isolates DC.
1. how does your company measure this parameter?
2. What instruments and equipment are used, can you describe the test method in detail, how to give the signal and add bias?
3. Can we give some solutions to our current situation?
Thank you in advance.
-Mark
