We found leakage current about 2.6mA in TMUX154E when CC=VEN=VSEL=0V, 1.8V for A/B port.
It should <2uA leakage in this condition. Does there have any reason to cause this leakage? thanks!
Jeff
Jeff
Hello Jeff,
This is a very high leakage current. The device might be damaged.
Is this issue seen across multiple devices?
Nir
Hi Nir,
We found leakage depend on our test tool.
But we have question aboout If VDD = 1V~2.5V, port A/B have 1.8V, it may possible have leakage current from portA/B to VDD?
Thanks!
Jeff
Hello Jeff,
What do you mean the leakage is dependent on the test tool? How much does it differ?
I can't predict device behavior at VDD = 1V~2.5V this is below our recommended operation conditions.
I recommend to use the TMUX154E within its specifications limit.
Nir
Hi Nir,
=> We found leakage caused by test tool. There is one path caused the leakage.
Hello Jeff,
VCC = 0V is when the device is considered powered off.
VCC = 3V min is when the device is considered powered on.
Voltage between 0 and 3 is when I cant guarantee the device behavior since it exceeds the specifications limit in the datasheet.
Nir
