Other Parts Discussed in Thread: DP83630,
We are using a TI DP83630 external PHY in RMII master mode, which produces a 50MHz REF_CLK.
That 50MHz REF_CLK has to be switched or multiplexed with another signal so they can both share an input pin on another micro.
Question: Will the TMUX1119 have enough bandwidth and low enough Ron to pass this 50MHz REF_CLK without delaying or distorting it too much?
If the TMUX1119 cannot meet this requirement can you suggest another switch/mux part number that is better suited.
