Hello TI Team,
I am designing a CAN network where I need to switch CAN-H and CAN-L between two different CAN transceivers (or buses).
Part in consideration: TMUX1109
Data rate: 500 kbps to 1 Mbps (CAN 2.0B)
Application: Use TMUX1109 as a multiplexer for differential CAN signals
Question: Will TMUX1109 maintain proper signal integrity, common-mode voltage range, and differential impedance at these speeds?
If not recommended, can you suggest a TI multiplexer/switch suitable for CAN bus switching?
Thanks & Regards,
Sakthibala V.
