Hi Sir :
How to connect the power supply heel reset foot reuse? Is there any other recommended way to achieve power and level switching by using a 2-cutting 1-analog switch on the development board, which takes up too much space?
Hi Sir :
Hi Sir :
I just want to know how to connect the RESET/VL pins of TMUXS7614D, and there is an additional analog switch switch added to the EVM, which increases the board area and cost; I want to know how SCH should be designed without external chips for REST/VL ;
Hi Anson,
You do not need an additional analog switch to control VL/Reset. This pin is the power supply pin of the SPI block for TMUXS7614D, so you just need to connect this pin to a power supply. Giving this pin a high will turn on the SPI block, giving a low will turn off the SPI block.
Katy
