TS3DV621 HDMI MUX question
Other Parts Discussed in Thread: TS3DV621, TMDS442
Is it correct to use two TSDV621 2:1 mux ICs both connected to the same output in a 4x1 mux configuration?
Regards.
  • Hello Ander,
        It seems correct, however we do not have data regarding such application. Also, for a safe operation, I think you must deactivate both TS3DV621 (EN= L), before select and activate and select the desired input.
        Other solution could be the TMDS442, if it fits to the design requirements.
    Diego.
