TS3A4741 Vcc bypass capacitance value
Other Parts Discussed in Thread: TS3A4741
on my behalf of the customer:
Customer design in TS3A4741 for a robotic application:
In this part typical application, bypass cap use 0.1pf, that should be 0.1uF?
  • Ranita,
    As you can see in the datasheet in the detailed design procedure and the power supply recommendations section, our signal switches can operate without any external components.  However it is always a good practice to place bypass capacitors as close to IC supply pins as possible to filter out any unwanted noise.  0.1uF capacitor is typical for most applications but different values or multiple caps may be need depending on the quality of the power supply.  Thank you for pointing out the typo in the datasheet PF should be pF anyway.
    Thank you,
    Adam
